Текущее время: 02 июн 2026, 16:15
 Заголовок сообщения: продаётся Yamaha SuperJet FREESTYLE tuning
СообщениеДобавлено: 02 апр 2013, 12:20
Техника: yamaha sj760 (square nose в тюнинге)
ПРОДАНО!
описание тюнинга:
Exterior
Crazy House Light Weight Free Style Hood and Nose(Special Model)
168,000Yen
Crazy house Free Style Foot Hole
14,700yen
Crazy House Scopper Valve(Special Style)
16,800yen
Crazy house reinforcement Engine room(only Right side)
15,000 yen
Crazy House Free Style Ride Plate (Short Style)
19,950yen
Crazy House Handle Pole Braket(Aluminum)
31,500yen
BUN Freestyle Strong Food Fuck(Free Style)
10,500yen
PowerPoint Hood Rutch
8,400yen
Hydoro Turf Mat (Diamond Style)
42,000yen
BUN Freestyle Foot Belt(Free Style)
6,800yen
AC Aluminum Handle Pole(-3 Short Pole)
16,800yen
Crazy House Strong Steering Cable(Free Style)
31,500yen
AP Design Chin Pad
15,800yen
SE Special HandlePole Bush(Silent style)
3,150yen
SE Aluminium Fuel Cap(Bule)
6,800yen
SE Aluminium Throttle Lever(Silver)
10,500yen
SE Aluminum Front Bush(Silver)
4,200yen
J-Line Aluminum rear Bush(Silver)
3,500yen
UMI Free Style Handle Bar(Straight Style)
9,800yen
Renthal Grip (middle hrad)
3,150yen
XFT Short style Steering plate(silver)
16,800yen
Wamilton Special Intake Gate
21,000yen
Engine
DASA Power Valve Cylinder(Max 88mm Piston) (Special Modification inside)
315,000 yen + 350,000yen DASA Modification Clank case
DASA Aluminium Head and Dome
43,050yen
DASA 49mm Special Carb
191,783yen
MOTOINE Accel wire ring
4,725yen
WISECO 86mm Forged Flat Piston
42,000yen
BUN Freestyle Intake Manifold
27,800yen
V-Forse CARBON Reed Valve (V2 Style)
27,000yen
SE Flame Alester (Short Style)
10,500yen
Factory B Pipe Special modification By MAEKAWA for Power Valve
278,000yen
Factory Pipe Water Box (special modification inside)
84,000yen
MAEKAWA Engineering Fuel Pick Up
21,000yen
MSD ignition (BUN Freestyle special setting)
250,000yen
BUN Freestyle MSD Aluminium plate
17,800yen
Deck Special Batteri case(Stainless case)
10,500yen
Pump
Skat Track MAGNUM Pump 144mm(Set Back)
350,000yen
Skat Truck Impeller 14/21
BUN FreeStyle Drive Shat SET BACK style(for MAGNUM Pump)
60,900yen
SE Steering nozzle(special modification)
15,800yen
По просьбе вышлет вам любое фото/видео и информацию о гидрике :good:
IMG_8016.jpg [ 160.17 КБ | 4396 просмотров ]
IMG_8017.jpg [ 167.9 КБ | 4396 просмотров ]
P1010060.JPG [ 172.05 КБ | 4396 просмотров ]
P1010076.png [ 1.04 МБ | 4396 просмотров ]
P1010077.JPG [ 153.58 КБ | 4396 просмотров ]
P1010078.png [ 1018.7 КБ | 4396 просмотров ]
Последний раз редактировалось admschik 19 июн 2013, 18:16, всего редактировалось 1 раз.
 Заголовок сообщения: Re: продаётся Yamaha SuperJet FREESTYLE tuning
СообщениеДобавлено: 09 апр 2013, 02:54
Если не обман(извеняюсь сразу) то лодка достойная :shock: ищите варианты обмена лодки на деньги.
СообщениеДобавлено: 26 апр 2013, 17:20
Техника: SJ-800
Странное дело... где на*бывают???
на АВИТО пишет : ...поршня плоские 88 мм, ниши под ноги, коленвал 10мм...
в спецификации пишет на ГИДРИК.РУ : Engine - ...WISECO 86mm Forged Flat Piston
на АВИТО : ...водомёт с валом skat track 148 мм...
в спецификации на ГИДРИК.РУ : Pump - ...Skat Track MAGNUM Pump 144mm(Set Back)
какие ещё "неточности" таит твой друг (сей продавец)???
СообщениеДобавлено: 29 апр 2013, 16:45
не друг, я лично его не знаю. Почему я ему доверяю, так это потому что он может прислать любые фотографии, видео, отправить гидрик на своё имя в любой город, после подтверждения доставки переписать имя получателя на покупателя. Конечно он может потом получить деньги, а гидрик назад к себе в благовещенск переслать, сам оплатив доставку туда-обратно, но где вы видели таких кидал??? К тому же объявление висит и на Jcboat и на авто.ру. Везде один и тот же номер, один и тот же адрес, одно и то же имя, одна цена. Как правило мошенники по такой схеме не работают. Насчёт нестыковок по описанию даж не знаю. То описание, которое тут представлено - это копипаста письма бывшего владельца-японца. А продавец сам когда составлял описание на авито мог что-нибудь и напутать. Просто я напряг человека, а потом не потянул покупку. Обещал ему помочь продать гидрик
