Текущее время: 18 июн 2026, 16:52
СообщениеДобавлено: 10 июн 2012, 19:53
АКВА ТРАКС Ф-15 очень каву напоминает...
http://powersports.honda.com/water.aspx
AquaTrax F-15
ENGINEEngine Type 1470cc liquid-cooled dry-sump inline four-cylinder
Bore And Stroke 79mm x 75mm
Induction Self diagnostic PGM-FI system with automatic enricher circuit
Ignition Computer-controlled digital with three-dimensional mapping
Compression Ratio 11.1:1
Valve Train DOHC; four valves per cylinder
DRIVE TRAINPump Axial-flow single-stage 155mm jet pump with reverse
Hull Fiberglass Reinforced Plastic (FRP) outer hull, inner hull and deck
Transmission Direct shaft drive
DIMENSIONStorage Capacity 23.1 gallons
Length 133.8 inches
Width 49 inches
Height 42.4 inches
Seat Height 49 inches
Curb Weight 933 pounds (Includes all standard equipment, required fluids and a full tank of fuel - ready to ride)
Fuel Capacity 18.5 gallons, with low-fuel warning
OTHERAvailable Colors Metallic Silver/Metallic Black Hood, Candy Orange/Metallic Black Hood
Model Id ARX15N3
2000-Aquatrax-F-15X-i02.jpg [ 218.72 КБ | 3259 просмотров ]
СообщениеДобавлено: 10 июн 2012, 19:54
Младший брат наверное...
2009-aquatrax-f-15x-11.jpg [ 273.62 КБ | 3257 просмотров ]
